Hi there,
I was just trying to get that working but didn’t find a way to do it.
I have a X52 Logitech HOTAS Joystick as the only “RC Input” and now i would like to toggle my relay with a momentary button on said joystick. I can momentarily switch it with the “DO_SET_RELAY”, but it releases when i let go off the button. Has anyone got an idea on how to do this?
This is the expected behaviour because the ardupilot will just copy the logic state of your button into the relay, so imagine your JS button is sending a PWM value interpreted as logic level HIGH when pressed and LOW when unpressed. This way, DO_SET_SERVO will only apply the same logic level to the relay output. In order to fix it, you can try to setup your joystick button to a latch functioning, so the logic levels are toggled at each button press (really do not know if it is possible with your device, not familiar with it).
