ARDUPILOT on BetaFlight Pavo Femto, AHRS_ORIENTATION etc.
Hi all,
set the AHRS_ORIENTATION = 8 as the FC is mounted upside down, but then artificial horizon ROLL axis direction is wrong again. Tried different other values + also manuall settings, but does not solve the problem, if you get roll + yaw correct then pitch again is wrong (shows as if drone is lying on it s back). YAW180+ROLL180 is the value i was looking for but this is not provided as a constant.
Also repeated the Accelerometer calibration process several times, changing roll direction also has no effect.
btw: only indoor flying is intended, so no GPS, no Compass … wanted to add Benewake LIDAR Sensor for Alt Hold or maybe also optical flow sensor. Thats why removing betaflight from FC + replacing it with Ardupilot. Also still can not lift of … arming only slowly rotates props some times then switches them off again …
YAW180+ROLL180 I would say is just pitch180. If You have photo how the FC is mounted and if there are any “FRONT” arrows on it, it would help.
Are you certain you are interpreting Mission Planner’s HUD correctly? It’s a common error for those not familiar with aviation instrumentation to mistake its presentation for “backwards,” particularly in the roll axis.
After checking the orientation in real flight … everything is correct … and yes think i was not interpreting correctly the roll …
