Hi.hello I have a problem with the Mission Planner Pre-Arm Hardware Safety Switch. What is the solution to the problem?
First explain the problem in more detail.
What are you expecting?
What is happening instead?
According to the Pre-Arm Safety Checks Documentation this might be what you are looking for:
Message | Cause | Solution |
Hardware safety switch | Hardware safety switch has not been pushed | Push safety switch (normally on top of GPS) or disable by setting BRD_SAFETY_DEFLT to zero and reboot autopilot |
