Hi
I am working on serious project about UAV. and I am using Unitek esc you can see below
https://www.unitek-industrie-elektronik.de/bamocar-d3
I will use pixhawk for this uav.And This esc controlled by CANBUS.
I know that Pixhawk have CAN controller and ardupilot have CAN library.But pixhawk can controll motor using pwm.
How can I implement CANBUS motor output on my pixhawk.I started working on it.But I wondered Is there basic roadmap.Can I add canbus writing script or other way.I need your opinion.
Can you help me.
My english is not good. because of that I am sorry.
Thank you.
Pixhawk already supports UAVCAN ESCs
http://ardupilot.org/copter/docs/common-uavcan-escs.html?highlight=uavcan
So all you need to do, is to change the existing code do add support for your specific ESC
@amilcarlucas Thank you for your answer
I trying to understand ardupilot code tree.And I draw arducopter wall chart.Every loop ends at HAL library and every process help converting pwm output. And pwm produced by output_to_motors() function in AP_HAL as you can see this link https://github.com/ArduPilot/ardupilot/blob/master/libraries/AP_Motors/AP_MotorsMatrix.cpp#L72
This function have 2 part.First one is calculating pwm second one is writing pwm. I thinking that I can add canbus write fuction in second part using AP_UAVCAN functions.
Is this way can be right way for implementing CANBUS on my pixhawk.
Ask that at:
