Have you tested any of this ?
€ 875,32 | MyFlyDream Crossbow Automatic Antenna Tracker AAT
No, but they seem to have a good following. The mini Crossbow has a good price. Check out the threads on RC Groups below.
MyFlyDream mini Crossbow AAT
Maybe it’s the best Tracking Antenna?
Thanks can i ask you do you know a good telemetry link for more than 60km i found this one https://store.cuav.net/index.php?id_product=38&rewrite=cuav-p900-radio-data-transmission-module-&controller=product
This will work with myflydream antenna tracker
The RFD radios work very reliably over great distances.
@GregCovey Hi, Thanks for this post.
I am facing an issue that when I connect my antenna tracker with mission planner, I can only see my antenna tracker’s location on MP but I cannot see my quad.
How can I solve this?
Thanks in advance for your help.
Sorry for the bump but were you able to find a solution for this issue?
Please how did you do it?
Connect two telemetries to your GCS. One of the telemetry should be paired with your drone’s telemetry whereas the other telemetry should be paired with your antenna tracker’s telemetry to communicate with Antenna Tracker.
After making these connections, simply follow the steps as mentioned here:
discuss.ardupilot.org/t/antenna-tracker-step-by-step-setup-and-simulator.
I will try it. Thank you.
