Hi, everyone.
I’m trying to tune the FlowHold flight mode to avoid wiggling, but without success. My quad is an under 250g 150mm X-Quad using Kakute F7 AIO, TFMini LiDAR and ThoneFlow OF sensor. With default parameter values, the behavior is not so good. You can see in the video below:
As suggested in another topic, I’ve changed the FHLD_FLT_HZ and FHLD_XY_FILT_HZ to 2. It really stops shaking, but the position starts varying in a bigger circle. The related parameters are:
- FHLD_BEAKE_RATE
- FHLD_FILT_HZ
- FHLD_FLOW_MAX
- FHLD_ QUAL_MIN
- FHLD_XY_FILT_HZ
- FHLD_XY_I
- FHLD_IMAX
- FHLD_XY_P
I don’t know exactly what these parameters do. I have just an idea of 6 and 8 based on other PID controllers. I will keep trying, but if someone already got good values, please help me.
Regards!
