As you see in the following picture, I have some sucessfully logs before the problem happen.
On the last flight, copter with pixhack-v5 controller took off and landed without accident. The log is set to start after ARM, and I didn’t change any parameter about log during these flight. What are the possibilities that would cause this?
This problem also happened in pixhawk before.
Could it be a bug in code?
I’d try reformatting it. If it happens again, might be time to replace it.
Good luck.
This has actually been an on-going problem in 3.6 and I think it’s in ChibiOS. The problem is known and I believe tridge is addressing it. It is indeed random. The ground station should announce “bad logging” or something when it happens. Reboot the controller and it normally goes away.
Thank you all the same.
Yes, It happens without any signs. And I quite sure that it happened when ardupilot used PX4 firmware, I want to know why the whole log is failed, I think the error happen at beginning, or some valid data will take the memory storage.
Yeah, it’s definitely happening at boot. I had it happen twice in a row yesterday with a Pixhack V3 running 3.6.3 ChibiOS. On the third boot it took off and ran fine. It is out of my dept but I know tridge is working on it.
Thank you and the developer. I think we can keep in touch to track this problem untill it be solved.
