Ardu Copter Build Errors with cygwin using waf
I am not been able to compile Arducopter 3.6 using cygwin with waf.
followed procedure as per link(http://ardupilot.org/dev/docs/building-setup-windows-cygwin.html#building-setup-windows-cygwin)
Instead of cloning arducopter i downloaded zip file removed internet mark as i dont have a internet connection there.
I manually downloaded all modules required (i.e. waf, UAVCAN, PX4NuttX, …)
ErrorBuildArduCopter
it configures board successfully but returned 128 at:
Command [’/usr/bin/git’, ‘rev-parse’, ‘–short=8’, ‘HEAD’] returned 128
Plz help resolve issue, or refer other link to resolve it
also waf check result shared what repercussions is gtest library not foud though i downloaded and placed in required folder but i think does not work that way:
The Ardupilot build process requires that it is downloaded as a git repository. It won’t work if you’ve just downloaded it as a zip file.
