APSync with Nvidia Jetson TX2 Dev Kit + Pixhawk
Hey Guys,
I have successfully integrated a RPi v3 b+ model to communicate with Pixhawk 2.1 (the cube).
http://ardupilot.org/dev/docs/raspberry-pi-via-mavlink.html
Now I have purchased a Jetson TX2 dev kit and I wish to connect (for now) the entire dev kit to the pixhawk.
(Flashed with Jetpack 3.3)
Initially, since both the RPi and the dev kits both have UART and are both ARM, the setup should be similar however it does not seem to work. (followed the manual precisely except for step “Disable the OS control of the serial port”)
Important: The Jetson, when connected to the pixhawk and powered on, would not load up and constantly reboot. any idea why this is happening?
In addition, I saw that it is possible to flash the TX2 with an APSync image, however, I have a few concerns with this hopefully I could get some answers:
  1. How does APSync affect the other aspects of the Jetson without the interaction of the Pixhawk? Will it just create the access point and the Jetson behave as though nothing else happened to it?
  2. Is it possible to disable the access point and data flash loggers? I have an RF device connected to the pixhawk and I just want the TX2 for video processing before sending it to the ground.
Any advice/ help is greatly appreciated!!
Almog
APSync is layered on top of the image provided by nVidia. You can see all
of the changes made to the image in the ardupilot/companion repo. We do
fiddle some bits and pieces - logging in as the apsync user, that sort of
thing.
  1. Is it possible to disable the access point and data flash loggers? I
You can comment stuff out in /etc/rc.local to stop stuff running.
The access point you will need to use “nmcli” to disable. Possibly
something like:
nmcli connection modify WiFiAP connection.autoconnect no
Peter
Hello, I have not flash the APSync to TX2 yet, or the concern of lost of all the python packages and the environment I have build, will this process(Flash APSync) cause that terrible consequence? (Noticed that APSync is a Linux release)
Thanks a lot!
Yes, it replaces the image present in the TX2.
It would probably be a good idea for you to work out how to back your work
up, anyway, even if you decide not to flash APSync on there!
Hello guys,
I have a Tx2i and a pixhawk 2.1. I want to use the TX2i with Ardupilot. I flashed the Tx2i and then flashed it with APSync. After flashing it with APSync, it is not booting up. It was before. Do you know what went wrong? I am suspecting that’s a space issue. Not sure if it will work with an SD card though. Let me know your views.
Also, if I use an SD card, do I need to install jetpack and APsync on the card again? or does it get automatically installed on it when I flash the TX2i?
