APM 2.8 internal compass without external compass showing compass 1 error 99
The link below has details screen shots
https://drive.google.com/folderview?id=1ydjKvWF8YNbukGuJUGFYc1fghWtTWy6N
Is the jumper installed to enable the internal compass?
I am new … I have uploaded the pics in the Google drive
That’s that pin named as ?
It helped thanks. Alot
Internal mag enable I suppose. These APM’s are very old and no longer supported. It would be wise to replace it with a flight controller that will run the current firmware.
Can you please send a pic of jumpers installed… it will help so much. I am just a beginner in this… please.
I threw away my last APM a couple months ago but there is a picture above. What else do you need?
I got it thanx… everything works fine now.
bro i got same problem can u help me…i connected jumpers but it isn’t working
i am using same 2.8 but jumpers isn’t helping…can u tell me wat u did…
hi rahul
how did u solved the issue
im facing the same error pls help
Tenho uma APM 2.8, apesar de serem antigas sĂŁo
Muito confiáveis.
No desenho, o jumper de baixo Ă© o do Compass.
Com o jumper, funcionará o compass interno.
Sem o jumper, funcionará o compass externo.
Nas APMs, nĂŁo e possĂvel habilitar os dois compass, como e feito na Pixhawk, onde se um falhar ou outro assume.
Espero ter ajudado.
Hey i am facing the same issue did it work for you?? Please reply i am helpless i connected the pins still it doesn’t work
