Yes, my setup ist FC Matek F765.Version of Arduplane 4.0.7.
It should have a voltage sensor?
yes, frsky FLVSS/MLVSS voltage sensor or battery monitor to be enabled by BATT1_MONITOR
Does the FC765 have a current sensor?
Sven please read the docs, https://ardupilot.org/copter/docs/common-matekf765-wing.html writing them took many hours, this place is for support questions about my script, for general setup please post in the relevant threads
Please don’t get me wrong, you’re welcome to come back and ask for support once your basic setup is working
Thank you.
Sensors lost when I leave Yaapu. That is normal?
yes is normal, sensors are created by the widget and all widgets are paused when in the SYS/TELE/MDL menus
Thank you, it`s work all
Setup in Arduplane was wrong
Hi everybody,
I have released a new beta version for Horus class radios 1.9.3 , biggest new features are google maps support downloaded via Mission Planner maps prefetch tool and message history scrolling for up to 200 messages.
code is on github as usual
docs on setting up google maps is here
I wrote a simple tool (pretty fast) to resize and copy tiles from the MissionPlanner offline tiles cache to the SD card (or a temp folder), my tool supports map, sat, hybrid and terrain google maps
Google maps have to be enabled in the config menu since support for older format is set as default.
Quick comparison between google maps and bing maps, guess who is who
Screenshot of the scrollable message history for up to 200 messages (lower right the 3/4 in yellow means autoscroll is disabled to enable scroll all the way and will become 4/4 in white)
In the config menu zoom control channel has become “emulated wheel channel” for now the same channel will be used to control message scrolling.
The way the emulated wheel works is middle do nothing, up increase every 2sec, down decrease every 2 sec.
changelog:
Horus version 1.9.3 (beta)
Horus version 1.9.1 (beta)
cheers,
Alex
Hi Alex Hope all is well
Do we need to redo all the config files for all vehicles 1.9.3 (beta) ?
The zoom control option has changed in wheel emulation, all other options should be retained
@Alex, how do you save parameters after making changes? I made few changes on alert, batt capacity, etc. but after the power cycle, my transmitter falls back to default settings.
I am running 1.8 version
save is automatic whenever an item is modified, perhaps an issue with your model name?
Error:
Script syntax error
/Models/Yaapu/grxl.cfg
What is it and how do you fix it?
Hi Alex, Great work! Will have some fun testing in following days.
P.S.
I am waiting eagerly to test crossfire passthrough telemetry. AFAIK still not merged into ardupilot/master ?
Hi Alex,
Does this include RPM1 & RPM2 for helicopters?
No, RPM1 and RPM2 is waiting for an ardupilot PR to get in, it’s a matter of days, after that we’ll have RPM’s, problem is in Italy I’m not allowed to fly right now, we’re still under a partial lockdown in my town:-(
refers to “hybrid” and “tether” panels, which display voltage/power and energy in a different way, need to add more docs to the wiki
Okay, that make sense, thanks Alex.
@Alex, Here is the error message I am getting when I try to save parameters. I changed the model name but same issue.
Error:
Script syntax error
added some docs on how to download and setup google maps
