Hi Lee,
you do not specify your OpenTX version, should be 2.2.x.
The steps to configure the script as a telemetry one are quite simple, check the ardupilot wiki for details.
Double check that you do see yaapu9 selected in telemetry screen1 when you get back to that screen.
Hi Alex
First, Very Very Great job.
I am using the yaapu telemtry in my Frsky QX7, its working all well.
But I found that the max number of satellites is 15 while my GPS always have more than 15 satellites.How to fix this problem?
Hi @FireFly,
Thanks for your kind words!
Unfortunately 15 is the max number that ardupilot can send via passthrough telemetry, so you’ll never get a bigger value. Hdop is accurate though and a much better indicator of gps precision.
There’s also a note in the docs but I suspect it’s not that clear
So in my last post I indicated that I got the script running on my Taranis. Although that is true when using the telemetry screen I always see NO TELEMETRY. I have verified through the radio that the values are being sent on page 12 of my model setup I can see all of the values listed and watch them update. Is it possible that the script needs to be modified to account for sensor indicator spelling? here are my values…
Cels, RSSI, RxBt, VFAS, Curr, Alt, Fuel, GSpd, GAlt, Hdg, Tmp2, Tmp1, GPS.
Hi Lee,
judging by the name of the sensors you discovered I’d say you selected the wrong frsky protocol.
You should select SERIALn_PROTOCOL=10 (frsky passthrough telemetry) but you probably have set SERIALn_PROTOCOL=4 (frsky telemetry).
Alex, is the lowest critical cell voltage alarm still 3.2V min? been since 1.6 days that I have updated( nice to see imp/metgric units auto select now!), but I am now using Liions in some planes and need to be able to set that alarm down to 2.8V (2.5v is min cell for Liion)…has this been changed, I dont see anything in later rev notes…
thanks
Hi Henry,
the limit has been removed starting from version 1.7.1 on taranis and version 1.7.2 on the Horus.
Imperial units have also been implemented as well as ft/min for vspeed
This is the relevant changelog
Taranis version 1.6.2
moved flight modes to separate files to optimize memory
added support for FlowHold and Follow new copter flight modes
added groundspeed/airspeed unit configuration as menu option
moved flight timer to OpenTX timer 3
added spoken flight time to flight timer alert
added support for dual FLVSS + single power monitor with split load in dual battery view
fixed mavlink message severity unpacking
fixed first timer alert would not play
added dedicated sounds for critical/non critical messages
added simple/supersimple support with vocal alerts
improved cell count detection with new algorythm
added german language support
many memory optimizations
Taranis version 1.7.0
units settings for distance and altitude inherited from radio settings (imperial/metric)
units settings for horizontal and vertical speed selectable from config menu (m/s,km/h,mph,ft/s,ft/min)
implemented cohen-sutherland algorythm for hud line clipping
added imu temperature support
fix for roll and pitch overflow
removed Tmp1 and Tmp2 OpenTX sensors
moved all sensors to last instance 0xF of the respective frsky sensor ID (requires a new sensor discovery)
added ARM sensor to expose to OpenTX arming status
fixed home icon position when angle beyond +/- 90
some code refactoring
X9D: removed power from left panel
X9D: added efficiency on left panel as mAh/speed
Taranis version 1.7.1
fix for battery levels alerts, now voltage needs to stay below level for 4 seconds before triggering alerts
fix for limited battery alert voltage range, now from 0 to 50V
fix for IMU temp decoding
fix for landing complete alert, now played only if motors are armed
Taranis version 1.7.2
fix for battery level2 alerts not repeating after being triggered
fix for OpenTX GSpd sensor unit, now m/s
fix for consumed battery mAh greater than battery capacity
Thanks for the tip Alex in the other thread…that got everything working…I just didnt think that not having RSSI programmed in the FC would prevent the script from getting info…am used to using either 3dr radio telem links directly without FRSKY conversion or FRSKY RX telem links with this script which inherently have RSSI incorporated…
