just a blind guess, on pixhawk 2.1 there only are 4 uarts availbale for general use and serial5 is hard coded to debug, Maybe setting a protocol on serial5 did brake something?
Hi Alex,
serial5 can now be used not only as a debug, but as a serial port, as outlined here https://discuss.ardupilot.org/t/serial-5-pinout-on-pixhawk-2-1/29392. and here https://github.com/ArduPilot/ardupilot/pull/6761.
Plus, the unexpected behavior as outlined above happens, whether SER5 is active or not.
Could this have to do with the Frsky passthrough protocol in some way?
i am using serial 5 for my Frsky passthrough on 3 cubes 2.1 and 2 pixhawks with out an issues
And here it does not work… I had started with standard/ stock parameters and have not done “grave” modifications or parameters (as far as I am aware).
Regarding the serial ports 1+2, I have only changed between values 1 and 10, no additional parameters changed there (plus the Frsky port sets it’s own params anyways from what I understand).
Anybody have a smart idea what could be missing here? I am using a PH 2.1 from one of the very first batches, if that makes any difference?
I have no idea but by a quick glance at the code the library uses ardupilot serial manager and does not make any assumptions on the port.
Would be interesting to trace the serial port with a logic probe and see if it’s indeed sending anything at all
Thanks for checking!
I also had been interested in that when I first saw that no signals seem to come out - but may not be savvy enough to do this. I had found some instructions though and might give it a try to see if anything is sent.
on the tx are you getting rx rssi and rx battery level with out any other plug into the S-port on the RX ?
Yes, these values can be displayed on a custom telemetry screen in the Taranis.
I have done some more testing these last few hours and am thinking that the TELEM2 port of the Pixhawk 2.1 simply is defective.
While switching over the Frsky telemetry cable from TELEM2 to TELEM1 did bring a result (telemetry was displayed), I later found out that this unfortunately did not mean that now the radio modem was working while connected to a properly configured TELEM2…
This hardware is still from the first batch of Pixhawks, and I now think there is a manufacturing defect.
So thanks for trying to help solve this, seems to be a hardware issue.
Hi everybody,
new release for the Horus radios
Horus Widget Version 1.7.1
- flightmodes loaded at runtime based on detected frametype
- units settings for distance and altitude inherited from radio settings
- units settings for horizontal and vertical speed selectable from config menu
- fix for potential divide by zero on hud drawing code (implemented cohen-sutherland algorythm for hud line clipping) thanks @cipta
- fix for roll and pitch clipping
- removed Tmp1 and Tmp2 OpenTX sensors
- moved all sensors to last instance 0xF of the respective frsky sensor ID (requires a new sensor discovery)
- added ARM sensor to expose to OpenTX arming status
- removed power from left panel
- added efficiency on left panel as mAh/speed
- fix for telemetry reset on model change
- added script reset on timer 3 reset (motors have to be disarmed)
- fix for battery levels alerts, now voltage needs to stay below level for 4 seconds before triggering alerts
- lcd panel backlight control from script for messages/alerts/events (follow this guide to enable)
- fix for limited battery alert voltage range, now from 0 to 50V
code is on github
feedback is welcome!
Any of the serial ports that have Rx/Tx pins should work for telemetry. Just set the protocol for that port accordingly. I have Pixhack V3’s in helicopters and I’m running the FrSky telemetry on the Serial5 port, which is actually the GPS2 and Debug port otherwise. Just use the first four pins in the port and set the protocol to what you want. It works fine.
Just make sure you get the Rx and Tx pins hooked up right or it won’t work, though. I got a C&T cable that I had to reverse the Rx and Tx pins on to get it to work. There’s little arrows on the board that point in or out on the Rx and Tx. The arrow pointing out goes to the Rx pin on the controller port. It came wired backwards.
Thanks for your insights and pointers. Having dealt with this for hours and trying various scenarios, I believe by now I have gotten a reasonably good understanding of the correct settings and interactions and have heeded all instructions and tips I could find - with no joy.
Having reset the board to defaults and having tried again - with the same results, I now strongly assume it is a hardware issue, and am sending the board back to the dealer.
i think there may be a hardware issue i have just spent the night converting pixhawk chopper with pas through that works to a cube for the life of i cannot get it to work on serial 5 so i remove the cube put back in the pixhawk and it works i have other cubes that works on just not this one i wonder if they have made some change in the newer cubes ? this cube came with a remote usb cable and buzzer in one cable
got it to work on the 2 of my newer cube’s it will only work on the gps 2 port
I had bought a new Pixhawk 2.1 yesterday, and the serial ports now behave as expected (with FrSky telemetry coming through on TELEM2 and the modem connected to TELEM1).
So I believe the issue reported earlier was hardware related.
Hi everybody,
new minor release for the Horus radios X12 and X10
Horus Widget Version 1.7.2
- fix for imu temp decoding
- fix for landing complete alert, now played only if motors are armed
- fix for limited battery alert voltage range, now from 0 to 50V (was missing from 1.7.1)
- changed min alert interval from 10s to 5s
code is on github
Hi everybody,
new minor release for the Taranis radios X9D,QX7 and X-Lite
Taranis Version 1.7.1
- fix for IMU temp decoding
- changed min allowed alerts interval from 10s to 5s
code is on github
cheers,
Alex
Hi!
I’m having trouble getting telemetry data from frsky passthrough protocol.
I’m using pixhawk cube, taranis x9d+ and frsky x8r receiver.
So far I have tried Telem2 and GPS2 port, with protocol 10 and baud 57. No telemetry data. According to TI, I tried to use Telem1 port, but when i set telem1 port protocol to 10, then when I power up my board, the GPS lights stay dark and also it wont connect to MP via mavlink. Also no telemetry data.
Anybody has idea what could be wrong? May the cube be defected?
interesting, got chance to try another cube, and the same error, when I set serial 1 protocol to 10, its not possible to connect to the MP via mavlink, also the gps lights stay dark…
Thanks, will try this ASAP!
Perhaps it’s worth opening an issue to further investigate the problem, you’re not the first one to report it!
