Is it possible to have display on the yaapu lua script screen on QX7 , the "2nd RSSI between dragonlink and the plane that comes from the Eric’s Mav2passthru stream while running Mav2passthru as a Relay mode?
Currently on your script screen, only the RSSI between QX7 and R-XSR is shown on the top of the screen. 2nd RSSI ( between dragonlink and the plane) is available if searching sensors on OpenTx but I couldn’t find a way to display it on the first main screen. Currently I am displaying it on second screen but it would be great to have on the first screen in place of the existing RSSI (between QX& and r-XSR) . I am talking about in Relay mode only. Thanks.
I have a little issue with the latest yappu script running on QX7 ACCT. Issue is script starts announcing “No GPS” as soon as my GPS fix changes from 3D to dgps fix on my plane running latest Arduplane.
I am using Eric’s mavlink to passthru converter running on ESP32.
I briefly talked to Alex on email, but unfortunately the invitation I sent him from Ardupilot was private and he could not open it. I hope this one goes through. Apologies, I have also been pretty busy here.
Sorry for the noob question. I’ve tried searching but without any success.
I got the Yaapu lua telemetry script working on a pixhawk using crossfire rx and radiomaster tx16s transmitter quite nicely and are enjoying it to bits.
I get constant feedback message “Loitering Data”. First I’m not 100% sure what this means apart from sending/receiving mavlink information.
Can I turn this alarm off and if so, where do I find the setting. I don’t want to turn off all sounds, just this (or any other) specific alarm/message
Did you get an invitation to Erics @Eric_Stockenstrom post where there is a small issue when gps fix changes to dgps, script starts announcing “No GPS”. Thanks
Thanks Alex, I suppose that was obvious. I didn’t realize the reason your script was announcing upon radio power up was because I had the widget screens installed on ALL models. This issue with EdgeTx (2.6/2.7) and running scripts is annoying. I know it’s not your issue but can’t seem to get any response from the EdgeTx guys. Even an acknowledgement of the issue would be something.
Am, Alex could not open the invitation because your original PM was private. We could work around this problem temporarily by limiting GPS_Status to maximum of 3.
I would like to use simple telemetry on my Horus + Frsky Gas Suite. I saw you developed a nice widget for it showing rpm, avg consumption, temp and residual volume. Where can I download it please?
That was developed for the Taranis X9D and X9E for a custom (not the stock ArduPilot one) Frsky telemetry library. It will not work on the Horus without considerable rework. I would recommend using Alex’s package, which is customizable for the Gas Suite sensors, for the Horus.
The actual Gas Suite scripts are horribly written and things like the fuel flow sensor do not work unless you have a turbine that has enough fuel flow to make the sensor reasonably accurate. With a two-stroke Zenoah engine in a 800-class machine the fuel flow is so low in level cruise flight it won’t even reliably turn the flow sensor. Alex’s package actually works and incorporates the important things.
I am trying to run yaapu on my X10S Express (OpenTX 2.3.15) with a FrSky SR10PRO and Gas Suite. I am looking to get the airplane telemetry data RSSI, RxBt, RPM, Residual Fuel Volume and Temp. Can I do this without the ardupilot?
