Thanks Alex but it’s not a file I can download. I don’t understand, sorry.
download this file https://github.com/yaapu/FrskyTelemetryScript/archive/refs/heads/dev.zip
and copy to your SD card only the content of the folders ETHOS/ALL/SD and ETHOS/X20/SD
Awesome, thank you.
Hi, not very difficult, save the original fles and play with them, on Horus radios the tune files have additional properties for the on screen position of the parameters so just try to find some room on screen and place the needed extra parameters there, all config is done via the lua files, the engine will render the new parameters just fine, on Taranis radios simply add the new parameters but do not add too many of them, stick with 10/12 max per page
Hey alex, just an update. Got the Yaapu script working on my X20. I have sent a video on our Ardupilot telegram group. And the thing is, what i have is Mav2PT on my dragonlink relay setup, and it works just perfectly. Although Im still lost on how to properly configure the screen widget to change some stuff, and how to update the maps, how to change zoom level…
Edit:
I got the maps updated, I just transferred the files from my X10s and load it on the Yaapu script. I also found that pinching the screen will zoom in/out the map. Maybe it will be handy if zooming can be assigned to a channel?
I recently updated the configuration on one of my Rovers to use a redundant receiver.
Both receivers are FrSky Archer RS models in ACCESS/FPort mode.
The primary receiver has passthrough telemetry enabled, which works great…except…
If the redundant (non-telemetry enabled) receiver is found first (or if the primary receiver connection is interrupted in any way), telemetry stops.
I have a momentary kill switch on the redundant receiver that is accessible because of the way I have things configured. If I briefly interrupt that receiver’s power, telemetry from the primary receiver resumes.
Is there a way to configure either the OpenTX architecture or the Yaapu script to always seek telemetry from a specific receiver?
Hi, I don’t have a solution for you, this seems to be related with receivers priority only, whenever the redundant non telemetry enabled receiver is active the other one looks to be isolated so the no telemetry issue is expected
@yaapu, I need guidance on a dual battery setup. (TX16S, v1.9.5, OTX 2.3.14) I have an analog source connected to BATT2_VOLTAGE_PIN. When this voltage is above some threshold, the telemetry scipt displays it in the left pane. When it’s 0V, I see the default GPSAlt/Dist/Travel display on the left. Is there a way to force VB2 display all the time, even if it’s very low or 0? Alternatively, is there a way to have BATT2_VOLTAGE as an OpenTX telemetry value, so I can display it in a separate page?
Hello Alex,
I guess I won’t be the first with this question, but is there a way to change the font color in the widget?
I’m using EdgeTX 2.7.0 on a Radiomaster TX-16S.
I can change the theme but with most of the other themes it just gets worse.
Regards,
Orson
Did you follow the link on GitHub for the edge tx version? You need to use version 1.9.6 or later
Yes my bad, I thought 1.9.5 was the latest, now it’s all good, thanks for the help!
I have done it and its working for all other paramenters except for the ATC_RAT_RLL_FF simple it returns “ERR_EXP”.
Here is the file if you could have a look ! Thank you in advance!
cheers,
Pedro
I am totally addicted to your telemetry script for the X20S. If you need additional testers with X20S, I will be happy to help!
Hello yaapu,
Is it possible to have display on the yaapu lua script screen on QX7 , the "2nd RSSI between dragonlink and the plane that comes from the Eric’s Mav2passthru stream while running Mav2passthru as a Relay mode?
Currently on your script screen, only the RSSI between QX7 and R-XSR is shown on the top of the screen. 2nd RSSI ( between dragonlink and the plane) is available if searching sensors on OpenTx but I couldn’t find a way to display it on the first main screen. Currently I am displaying it on second screen but it would be great to have on the first screen in place of the existing RSSI (between QX& and r-XSR) . I am talking about in Relay mode only. Thanks.
Battery left in percentage
i see. thanks for the info
Hello Alex,
I have a little issue with the latest yappu script running on QX7 ACCT. Issue is script starts announcing “No GPS” as soon as my GPS fix changes from 3D to dgps fix on my plane running latest Arduplane.
I am using Eric’s mavlink to passthru converter running on ESP32.
Here are the details of the issue on Eric’s thread:Mavlink to FrSky S.Port Passthru Converter for LRS or PX4 Pro - #711 by Eric_Stockenstrom
I have also invited to the private discussion with Eric where I have posted my logs. Could you please have a look when you get a chance? Thanks.
I briefly talked to Alex on email, but unfortunately the invitation I sent him from Ardupilot was private and he could not open it. I hope this one goes through. Apologies, I have also been pretty busy here.
