hi every one
today after autotune my copter with new motors i have a problem with my copter in the wind
when flying in wind with 20-25 km/h in loiter my copter losing its altitude till near ground and recover it
i want to make sure that my copter has no problem (i cant find any problem in log file) or my new motors cant generate enough thrust to resist against wind
60% throttle at hover is underpowered. As suggested to many others with similar thrust/weight ratio go to 4S power. I had a 550 size craft on 6S and would do so again if I were building another one.
ok i misunderstand about Andras Schaffers post
your mean and Andras Schaffer is this thrust is not enough to resist against strong winds and there is no any problem with generating max thrust by motors and propellers
yes ideal is 2:1 or less wight against thrust
ok correct me if im not true
this build will loss altitude when wind pressure is more than 2100g
calculation :
max thrust by motors X motrs count - copter wight
(800g X 6) - 2700g = 2100g
