Altitude did not recieved
Hi all. I have a problem with receiving altitude data from a barometer (141 command).
I try to receive data by setting MAV_CMD_SET_MESSAGE_INTERVAL and requesting a single message MAV_CMD_REQUEST_MESSAGE. But the message was not received. Also, I checked if Barometer is enabled and calibrated.
Many thanks for considering my request.
check the EK3 source for Z axis what has been enabled!
Thanks for your answer!
I set this parameter, and got a new message:
AP: No ap_message for mavlink id (141)
141 Is the code of ALTITUDE message
https://mavlink.io/en/messages/common.html#ALTITUDE
I have been asking RFD and Aurelia and DRS systems about this messsage for a while.
see my topic here.
Thank you for your answer!
Sorry, I didn’t fully describe the problem, we want to get the data on the companion’s computer.
Maybe these are related problems, but slightly different situations
Possiblities:
  1. Check the mavlink version is up to date?
  2. Check the code and try to access Baro Alt directly from mavlink and AP.
