Thanks for the quick reply.
In STABALIZE it flyes very smoothly (because of INS_GYRO_FILTER=60)
and seems to have no vibrations.
What is the best approach in that case ?
To disable the vibrations failsafe ( FS_VIBE_ENABLE = 0 )
To flash older firmware (Arducopter 3.6.X)
Try with higher INS_GYRO_FILTER, may be 80
To try to reduse that invisible for me vibrations ( some other filter Notch, soft mounted FC …)
Today I changed:
INS_GYRO_FILTER=80
FS_VIBE_ENABLE = 0
But the problem is not solved.
I rise the quad at about 5m in STABALIZE,
I switch to ALTHOLD at mid throttle.
The quad falls about 2-3 meters, after that suddenly rises up ( more than 10m) after that I switch back to STABALIZE.
When I arm in ALTHOLD on the ground it starts spinning the motors, but does not lift up at about 75% throttle. After that rises suddely.
crazy vertical shoot up in pos hold and alt hold is due to excessive vibrations every time. usually with a hard mounted FC.
on params front - review your PSC section, i copied it below. freq of filters in there have direct implication to that issue.
second, if you cannot suppress vibrations mechanically - use the notch filter. there is a whole tread about it on this forum. for medium 450mm drone i also give you sample params to use, but you will need to read it up and tune it properly as explained in the documentation.
