I want to use an external barometer and connected to the aircraft’s static ports. I bought the Alinan 4pcs Red 3.3-5V Digital Barometric Pressure Sensor
https://www.amazon.ca/Alinan-Digital-Barometric-Pressure-
Controller/dp/B09XQF7Y5Q/ref=cm_cr_arp_d_product_top?ie=UTF8
Which parameter should I put on the following parameters:
- baro_ext_bus
- baro_probe_ext
Thank you
