I have installed a speed sensor on the plane and calibrated it using the pre-flight in the action tap. After calibration the sensor, it reads values from 6 to 11 and it would read values if air blown into it
I have read sensor values should not be grather than 3. Therefore, I reset everything but sensor values were still 6 to 10. then I closed mission planner and connected the plane to APM Planner 2.0, calibrated the sensor and the value was 3.
Based on the above I decided to install the previous version of mission planner and after calibration the reading was 3. Then, I updated mission planner again to the latest version and values jumped back from 6 to 11.
Have any of you guys experience this? or is there anything ( values) that I have to change in the latest mission planner version for the airspeed to normal values?
Thanks again for your help.
Juan
