Is it possible to change the motor ordering in the AIO flight controller?
You just have to change the servo output parameters. Connect it however you want. If there is not a FRAME_TYPE already that supports it then run Motor Test in Mission Planner, which you would do anyway, and if it’s wrong re-assign the Servo outputs. Nothing to it.
