I want to change the output voltage of TELEM2 pins to 0V,so I download the pixhawk_toolchain and ardupilot code,and I just add some very simple code in ArduCopter.cpp like this(the code I added is in the end of setup() and the end of fast_loop() and the void Copter::pin(void) ):
void Copter::setup()
// Load the default values of variables listed in var_info[]s
AP_Param::setup_sketch_defaults();
// setup storage layout for copter
StorageManager::set_layout_copter();
init_ardupilot();
// initialise the main loop scheduler
scheduler.init(&scheduler_tasks[0], ARRAY_SIZE(scheduler_tasks), MASK_LOG_PM);
hal.gpio->pinMode(72, HAL_GPIO_OUTPUT) ;
void Copter::loop()
scheduler.loop();
G_Dt = scheduler.get_last_loop_time_s();
// Main loop - 400hz
void Copter::fast_loop()
// update INS immediately to get current gyro data populated
ins.update();
// run low level rate controllers that only require IMU data
attitude_control->rate_controller_run();
// send outputs to the motors library immediately
motors_output();
// run EKF state estimator (expensive)
read_AHRS();
#if FRAME_CONFIG == HELI_FRAME
update_heli_control_dynamics();
#endif //HELI_FRAME
// Inertial Nav
read_inertia();
// check if ekf has reset target heading or position
check_ekf_reset();
// run the attitude controllers
update_flight_mode();
// update home from EKF if necessary
update_home_from_EKF();
// check if we've landed or crashed
update_land_and_crash_detectors();
#if MOUNT == ENABLED
// camera mount's fast update
camera_mount.update_fast();
#endif
// log sensor health
if (should_log(MASK_LOG_ANY)) {
Log_Sensor_Health();
pin();
hal.gpio->write(72, 0) ;
then I add code in Copter.h like this:
void pin();
after those,I compile the code to px4-v2,and download px4-v2 to pixhawk,but the voltage of TELEM2 pins is still 3.3V, no change.I know there is something wrong,but I don’t know where it is.
I hope someone can help me .Thank You!
