Hello everyone I’ve been struggling with my drown for a while now and have been dealing with more crashes then flight time in the air l’m hoping maybe someone here can help me out these are my 2 flight logs from earlier today Flight 1: 1 took my drone up in loiter mode and it stayed in place fine when I tried turning left or right it ended up coming down and said accels inconsistent. Flight 2: 1 changed my loiter maximum correction speed and put it up again it flew better and let me go left and right but for some reason when I went forward and came back it ended up coming down again and now I have a broken leg. I’m tired of the constant crashed and just would like to enjoy my drone on my time off could anyone help ?
I was told to create a new thread so I’m hopefully I finally did this right first time here.
I have competed the guide and now have the methodic configuration and the newest updated mission planner what should I do next ?
I was hoping maybe someone could look over my flight logs and see why I crashed earlier and what caused it I feel like since it said accels inconsistent it could just be a easy fix hopefully
So yes but on step 5 or 6 I kept pressing upload secreted params to FC until the application closed itself out and said everything was completed but I looked at my parameters on mission planner and it changed my battery capacity to 30,000 when it was set to 20,000 and when I open the methodic configuration it’s showing a random picture that’s not mine which is a quad rotor mine is a hexarotor.
I just wanted to make sure it didn’t change my existing parameters and put random ones on since this is my first time dealing with this software
So now my parameters are all jumbled up and now what and I supposed to do ? I really don’t understand why I needed to do all of this in the first place if I crashed because of accel inconsistency then wouldn’t you just be able
To look at the flight log and see exactly what’s going on…???
No, that is not that easy, usually there is not a single problem, but a multitude of problems. And it takes a lot of time to fix them all. I find one, you fix it, then do a test flight, I find a new one that was occluded by the first issue, you fix it, and you fly again, I find the third one … You should get the point by now.
It is better, faster and simpler to start almost from scratch and correct the issues, one by one sequentially, the program guides you and points you to a small subset of the documentation. The subset that you really need, and sets some parameters based on your vehicle components. And it prevents you from making certain mistakes.
But you do need to follow the instructions and not skip steps.
I just had my parameters completely redone and now your saying I have to redo them again i really don’t understand can you just look at my flight logs and see what happened plz your telling me to do several other different things before even looking at the flight log and seeing what happened
@dkemxr could you plz help
Or assist me in the issue plz or just look over my flight log and lmk exactly what caused the crash or what may have caused it
Thrust loss on Motor 5, 6 dropped to stabilize and down it went. This look a lot like another log posted yesterday by someone else. Susie and the Grill Master.
I did notice that as well theirs said thrust lost on motor 6 and then motor 5 tried to stabilize it but my thing is it’s saying accels inconsistent and I changed the gps order like I say they recommended them too but I’m still stuck and can’t seem to figure out what exactly the problem really it
I’m not sure who that is I just know that my drones giving me problems that I’m trying to figure out how to solve so that being said what course of action should I take since it’s the motor loosing thrust then ?
