Today I update our test drone to check improvement on EKF.
HW us cube black with AC 3.6.7 and an arduino that works as converted between serial and Sbus ( serial input converted to Sbus output).
It works perfectly until I update to 3.6.10. Since now Sbus is not read correctly anymore. Pixhawk in failsafe condition. If I press reset button on arduino, random value are read on pixhawk and than stop again.
The change is a stricter sbus processing to detect failures in the sbus stream.
It is very likely that your arduino does not send correct sbus signal. Either stop bits or frame interval is incorrect.
