It could be like watching paint dry but I find it strangely relaxing,and I can do with a bit of that.It only took 5 minutes for all three axes.Sounds nice too with 5 BHP worth of motors up there.
Second autotune for this FC (Pixhack V3) in this frame.Nice flier on stock loadout but bang on after a couple of autotunes despite some strange looking numbers in the PIDs I have no idea what they mean but it flies right now and I can’t ask for any more.
I had the same experience with my Quad-copter,- total of 6 minutes, few day,s ago.
Drone - Sound? = I prefer the sound of my Helis, lol.
But drones are much, much easier to tune!
Nice job with the latest FW. Thanks a lot, Dev. team.
Wow!!! Excellent job!!!
I still have to auto-tune mine and I wish it could go as smooth as yours.
So you set AUTOTUNE_AXES = 7 to tune all 3 axes in one session; what “aggressiveness” did you set, the default 0.1 or lower?
Congrats again and thanks.
Cheers
gio
I used 0.095 for my latest. I had once earlier this year in FW 3.4.1. a bit of oscillation. That went away with a repeat A-tune and param. AUTOTUNE_AGGR = 0.095. Yes, AXES = 7. It stays now with PosHold in a small area. All is good with Auto-Tune now.
I actually did both autotunes in single sessions.The first one took longer,around 14 minutes,and this one about 5.I set the aggressiveness to 0.05 in accordance with the recommendations for large copters and it performed perfectly.
That’s a good question and I was trying to remember what I set it for.I followed the recommended numbers on here and I think it was dropped to 10Hz by one of the firmware releases and it caused problems.I’m sure it needed to be at 20Hz but I try not to rely on my memory nowadays.I’ll hook it up and check later this afternoon.
Right.That’s why I don’t rely on memory.
Yes,I set the filters to 10Hz and left them there.
I would say P value is still to high, you have a same wierd jitter sound like i had on my tarot x6.
Autotune is good to get decent values to start with for manual tuning
I have no idea of what a good value would look like but these did look pretty high compared to stock loadout.So many parameters have changed recently that I’ve lost track.It does fly nicely though certainly better than it did before the FC transplant.I’ve also never got around to manually tuning.I guess this is the one.
I did read once that when autotuning a big copter to drop the results by 10-15% to quiet it down a bit.Maybe I should start there.
Either the wiki is still to be updated or my values are more than twice as high as the maximum allowed.I suspect the values have changed in the code again.I look at the paramaters on the wiki and each one says Note: This parameter is for advanced users with no mention of how to learn how to become that advanced user.
Hopefully one day I’ll know what those values actually mean.Until then I’ll keep scratching around.
For autotune, PIDs in general I feel the same, the wiki pages about it are not update for AC 3.5. Autotune give me out of range parameter like stab Roll and stab Pitch at 16 and 18 as you, and in Alt Hold is not working well, and now I don’t know if the normal PID so high needs out of range Alt Hold PID or not. Is yours Alt Hold working good and what’s parameters are you using?
Yes I get that but it’s the different appearance of the values in 3.5,possibly 3.4 and above.As a base loadout I think you still get 0.135 Pitch and Roll Rate P value and 0.09 I value and this flew fine with those values.After autotune the values set are way higher - Roll P 0.63 something and Pitch P 0.49.
So it flies nicely but has that strange chatter on take off.I may try reducing the values by 10 - 15 % as recommended in another post but that still leaves the numbers higher than any other copter I’ve ever tuned.I was wondering if these values are because of a parameter rehash for 3.5.0 (or 3.4+).I think I’ll ask a seperate question about that.It would be valuable information for tuning a multirotor.
