I wanted to use Skydroid C20 camera with HM30, trhe C20 has RTSP H.264/H.265 output, can i use it with HM30?
C20 supports RTSP, so it can be connected to the HM30 system through a LAN port. By referring to the user manual of HM30, you will receive a typical wiring diagram and interface wiring sequence. Download link: https://siyi.biz/siyi_file//HM30/HM30%20User%20Manual%20EN%20v1.6.pdf
From what I’ve seen, you seem to have good knowledge of SIYI devices. May I consult with you about this topic?
SIYI HM30
Your questions in the link are best directed at @SIYI
Hi. For inquiries or questions about SIYI products, you can leave a message in the channel or visit the SIYI official website for technical support.
What is the beamwidth of the HM 30 during drone operation, depending on the antenna types you provide? Ex. high gain antena, omni antenna ( or ground control unit)
and also what is the value of Mbps during the 1KM range
Hello. I have verified that there are currently no specifications available regarding the beamwidth of the HM30 antenna.
The maximum download speed is 8 Mbps, and the maximum upload speed is 4 Mbps.
By the way, is it not possible to send photo files via Jetson NX?
am writing to inquire about the data transmission capabilities of the SIYI HM30 system for our UAV project.
Gemini says, “The Scenario: We understand that the HM30 functions as a transparent Ethernet bridge. We intend to transfer static image files (approx. 5MB each) from the Jetson Orin Nano to the Ground PC via the LAN connection, simultaneously while streaming the live RTSP video feed from the A8 Mini.
Our Questions:
Transparency: Can you confirm that the HM30 Air/Ground LAN ports act as a fully transparent bridge, allowing standard TCP/UDP socket communication for file transfer between the Air computer (Jetson) and Ground computer?” @SIYI
The standard is 8Mbps download and 4Mbps upload. We apologise for any confusion caused.
Yes. The HM30’s local area network is a fully transparent transmission link. You may use standard network protocols for communication.
Hello, if you try hard, you can get access, but it’s a very complicated and risky path, and twice😁 (whoever understood, understood). It is also possible to change the IP address of the ground module, but this is not a panacea due to the logic of these modules, even if you do all the manipulations so that after changing the addresses everything works, these modules will no longer work in their standard mode, the functionality will be slightly limited but working. I will not disclose the details, I like these modules and I do not want to harm Siyi)
Has anyone tested a setup with two HM30 Air Units and one HM30 Ground Unit, where the Ground Unit receives data from both drones and allows us to view the data from either drone one at a time by switching between them?
Is this possible with the SIYI HM30?
