Yes, it works perfect. I’m using 2 of them with 2 cameras in the air.
Thanks for the great support.
Now, I use this unit also for a Rover.
Look, the perfect stability of the gimbal cam.
Hello everyone, I am trying to take an image from the R1M camera on the drone with hm30. First of all, I took the image from the siyifpv application. The incoming image was a freezing image for seconds and shifts occurred as seen in the photo. I had the same problems when I received it with python over RTSP, the video is available in the drive link. I would be very grateful if you help me. Thanks in advance.
Hi i have a doubt regarding powering the siyi HM 30 air unit and ground unit for my drone. the drone runs on 6S battery and the HM 30 manual says that we can use 3S ~ 6S / 12.6 ~ 25.2 V to power the air unit so i will be wiring directly from the drone battery. the confusion is regarding the ground unit. the siyi manual has not given a voltage range for the ground unit power supply. in a separate brochure of the product i saw that it can be supplied 7 to 25 V. so i was going to power it with 6S on the GCS too till i read a post in this thread where one user experienced that some components inside the ground unit burned and bricked it when directly connected to the 6S battery. so my doubt is whether 6S is a good choice for powering the ground unit as well as the air unit.
Thanks in advance
regards
Thanks risto. i noticed that after sending the message. but then again i couldnt find which version onwards supported 6s. i bought mine last year (2024) and the firmware version is 0.2.6 and the hardware id is 6A02211792 . other than that i couldnt find any info. neither could i find if the 2024 models were supporting 6S
thanks and warm regards
Your unit is 6S safe.
The marketing page was updated in late 2023.
Thanks a lot for the prompt response
regards
Hello, I have the HM30 and playing video through RSTP link to VLC. It drops out pretty frequently and fails to reconnect on it’s own. I have to reconnect very often.
Do you have any suggestions?
P.S. so Mavlink over data link does not work if baudrate is more than 115200, OK, this is OK.
@SIYI I have more questions which are not covered in the manual:
Thanks!
@SIYI can you please reply ^?
Also is HM30 bidirectional or unidirectional system? Does it use acknowledges inside protocol? (i.e. does it need reliable ground to air communication same as air to ground?)
@SIYI Can you please send me the latest firmware for Ground unit, Air unit and HD-Ground?
Newer firmware versions are listed in the manual, but only older versions are provided on the website in the downloads section.
Thank you in advance !
Siyi, how can I change air\ground unit`s subnet from 192.168.144.0\24 to 192.168.1.0\24? I have some “unique” closed cameras where i can not change subnet ![]()
My HM30 ground unit appears to be heating up too much. Ive connected a 6S battery and it heats up quickly in a matter of few minutes. It also heats up similarly even if i connect a 4S battery. I’m using omini antenna with wirelessMode set to 5km fpv low latency. Any idea what might be the issue?
does HM30 support multiple cameras?
Yes, I use two one with the SIYI Ethernet Hub One to Two Ethernet Extention Compatible with UniRC 7 MK15 HM30 MK32 Air Unit
$ 18.69
Think of HM30 as a point-to-point WiFi connection that transmits bi-directionally std. Ethernet telegrams - you can pass basically arbitrary data, meaning also data from many (= 0,1,2,3,…, n) cameras, as long as the amount of data needed to be transmitted is less than what the HM30 RF link is able to carry.
one more thing, so i want to use the gorund station with the UniRC7, basically have a GSC connected the the HM30 ground station, but at the same time have the UniRC7 where i can see the live stream and also contorl the aircraft in manual mode
is this possible?
The disconnection issue is quite complex and may be related to firmware, usage environment, and the device itself. If frequent disconnections occur and affect your normal use. Please obtain technical support through the official website: Service and Support - SIYI Technology | Empowering and Building an Intelligent Robot Ecology
