Just tried to carry out an autotune on my quad (roll axis only). I tried this twice but ran out of battery before completion each time. Wondering if I can better set the starting parameters to give this a better chance to finish quicker. My quad:
Turnigy Talon v2 frame cut down to 330mm
2814 kv870 Sunnysky motors
4s 2600mAh 65c Turnigy A spec pack
8045 carbon/nylon props - very stiff
20a X-Rotor ESCs
AUAV-X2 FC
MOT_THST_HOVER = 0.26
AUTOTUNE_AGGR = 0.065
Want to get a better tune as in even slight wind gusts it is far too twitchy. Today there was zero wind but snow on the ground so I imagine battery not running at peak performance compared to on an average day here.
This is a very strange. I have not seen anything like this before.
So the good:
Vibes
motor output match
tests seem to be nice a regular suggesting the weather was nice
The bad:
P had to drop ridiculously low to stop overshoot
There appears to be a significant 50Hz oscillation going on
You haven’t set the MOT_BAT_VOLT_MAX and MIN (they should be 16.8 and 14)
The consistent overshoot is the funny one. How have you set up your ESC’s?
Can you provide some photoes, particularly in the autopilot mount, and have a look for any movement in the frame.
Leonard, Apologies, I didn’t pick up on your reply sooner. My copter can be seen in this gallery: https://goo.gl/photos/g4BwUr8mF75CSkUBA
Check the last few pics to see how it is now and some build details. Thanks as always, Paul
So the frame should be very stiff. Props and motors should react fast. So that leaves two possibilities vibration mounting and ESC firmware.
While I don’t think it is the servo it might be a good idea to leave it unpowered while you do the autotune.
Could you strap the autopilot down so the vibration dampening is effectively removed and run another autotune. If that doesn’t change anything then the only other thing to do is to flash BLHeli onto the esc’s.
Is there anything else on that frame that can bend and wobble? The gps mount for example??
Leonard,
Yes, the frame is totally solid and the props are also - hard to bend them. The motors have no play in the bells also, and the GPS mount is a solid aluminium pole - super rigid. I can certainly try tying down the autopilot - as you can see in the photos, it uses just a double thickness of sticky pads, so is already fairly firm in its mounting. If I can please ask - what are you looking at in the logs to determine that 50hz wobble? I looked at the gyro and accelerometer outputs and didn’t see anything specifically at 50hz.
It wasn’t released on Nov 9th when I raised this
Haven’t really had decent enough weather to try since (with 3.4.2 release).
I have actually determined that my short flight time could be down to my (Turnigy A-Spec 2600mAh 4s 65c) LiPo being a bit worn out - despite it being only just over a year old. Checked the IR and it is 75mOhms - so think its not lasted well. Going to try the next autotune using a better LiPo.
