I did not have a chance to fly it with these settings. A bit dark now and there is no wind. I will test fly it tomorrow and report back. I must say that the autotune went down differently this time. More crisp and purposeful.
But really something strange happen, the autotune made only a āsingle stepā and nothing more, it needs a robust radio input from me for making a second thiching, and so onā¦ was really a pain to make the autotune in 1 axis completed this way.
Henry-Iām using that same mini mount with even softer balls with a PixRacer. Overkill Iām sure but I have been able to manually tune it (210 quad) for good flight characteristics. This photo shows 3S but itās flying on 4S now which required a re-tune.
Just one question. I notice everybody put the battery on top. I have the battery at the bottom. I donāt race or even fly very aggressively. Is the reason just for safety or maybe something else?
I did my first flight this afternoon and it is a lot better if not perfect. Unfortunately there was not a lot of wind, but I hovered close to the road as cars drove by and could not detect any disturbance at the copter. I will do some more test flights when there is more wind and report back.
Henry-I think either will work itās just a matter of how you choose to build the quad. I actually have the PDB below the bottom plate protected with a plastic bash plate because there wanāt enough height with the FC mount and the ESP8266 radio without ridiculously long stand-offs.
Iāve done it both waysā¦
Iāll post pics of mine, in case it helps give anyone ideas about how to build one. I donāt know what the best way would beā¦ My only design goals were to make everything fit, keep it as light as possible, and keep the antenna as far apart as possible.
Then theyāve both been crashed and repaired a lot since I built them, so theyāre messyā¦
Yes, now you have a reasonable tune on roll and pitch you can do a yaw tune.
I am glad it is flying well!!!
On the battery thing. I saw a paper that suggested that having the CG just above the propeller disk was beneficial to control performance but I have not seen any clear indication that it is the case. I have done both but having the battery below makes it easier to mount the GPS.
The other day when Iāve set
ATC_RAT_PIT_FILT,40
ATC_RAT_RLL_FILT,40
INS_GYRO_FILTER,80
the copter seems to flight a lot better! but It can not perform the autotune for the rate noise as you explain me.
So Iāve set back:
ATC_RAT_PIT_FILT,20
ATC_RAT_RLL_FILT,20
INS_GYRO_FILTER,40
and the full parameter list in common for the below autotune session: post 1 roll.param (13.2 KB)
FC Pixracer firmware 3.5.2 rc2 hard mounted
motors 1306 2400 kv
propellers gemfan 5030
total weight 220g
battery Li-Ion 2S 3300mHA
the 3 last one :
Autotune Roll and Pitch
resulting PID
another Autotune Roll and Pitch
and the resulting PID
another AT roll and pitch
and its PID
The pitch quite often is overshooting, and the last tune seems terrible, after this last one Iām trying new AT but the copter is so instable, fighting to be stabilize after small breeze, heavily on the rollā¦ so Iāve stopped to make autotune and wait for your suggestions
Set Angle P to 10.
Increase Rate D until you see oscillation then drop until you donāt see oscillation.
Drop Rate D by 25%
Increase Rate P until you see oscillation then drop until you donāt see oscillation.
Drop Rate P by 25%
Increase Angle P until you see oscillation then drop until you donāt see oscillation.
Drop Angle P by 25%
Lets see where this takes us. I will look at a couple of changes in Autotune to address some of these issues and then we can compare what you get.
Here are two of my main development aircraft for a long time. The QAV was pretty much standard. The bigger one not so much:
Name: My kids call it Willy for some reason (donāt ask me!)
Weight: 940g
Motors: Sunny Sky 2208 2600 kV
Battery: 2200 mAh, 4s
Props: Gemfan 6x4.5, Gemfan 6x4 Bullnose, HQProp 6x4.5, APC 6x4E Speed, Quanum 6 x 4.5 Carbon (still experimenting)
Power: 1.4 kW continuous, 2 kW for short bursts
Current: 120 A continuous, 160 A for short bursts
Thrust: 4kg continuous, +6kg for short bursts
Has a custom 200A 4s power module based around the ACS758ECB-200U-PFF-T.
I have a question about manual tuningā¦
I understand the basics as youāve postedā¦ Increase until you see oscillation, then decrease until itās gone.
Iāve done that and get similar results to auto-tune. The copter is stable in a hover and gentle flight.
But as others are saying, in the wind or after a fast run or turn, it wobbles. If I fly forward fast and let go of the sticks it rocks back and forth a few times.
I donāt know if thatās a sign of too high PIDās, or too low. Is there a definite answer, or could it be either one?
I spend all afternoon making the in flight tune following the process you describe and with the setting u suggest:
ATC_RAT_PIT_FILT,40
ATC_RAT_RLL_FILT,40
INS_GYRO_FILTER,80
Yestarday already, when Iāve try these parameters seems to works so good on my light build (220g), but cannot works with autotune so today Iāve work with this manual tuningā¦
Iāve try indoor without any wind ā¦but I cannot see any significant difference in a large spectrum from min to max, Iām trying to explain:
Apart from Stabilize P (its linked ROLL and PITCH), Iāve focus only on ROLL part for the RATE,
I try with rate D Roll from 0.001 to 0.006, in the end I set at 0.002-0.003 only because it seems so much 0.006, but to be honest I could see some slight slight oscillation only at 0.006 and more, maybe!
After I try several time with rate P roll from 0.05 to 0.12 and I really cannot see any difference (all autotune before sets this from 0.03 to 0.05), now infact Iām flying with 0.12! only because outdoor with some wind it seems to have little more authority, but still Iām not sure to have any perceptible difference.
So Iāve set this 0.12 and also for I rate ROLL; passing to Stabilize P from 10 to 18ā¦and also here I cannot perceive any difference indoor and outdoor!
Iām lost, do I really have to make more extreme maximum?
Before during autotune I was seeing a huge impact from ATC_ACCEL_P_MAX and ATC_ACCEL_R_MAX, that we are not considering in this process.
In general I need to focus on wind ability PID, this is the important aspect because is the greatest and evident fault we have and Iām happy to see also other people are complaing here and in other theads.
Yours build seems so powerful, mine its hovering at 4A (220g) and at maximum arrives about at 10-12A, seems really different from yours example. My build have only 5mm clearance from every props, 5" 5030, really lightweight props
like 1,6 -1,7 gram each one.
Hi, Since you both mentioned Leonardās 120A figure, I just want to mention, he means that is the max power he can sustain. That isnāt his hover throttleā¦ Heās got 30A escās and motors/props capable of drawing that much power, so can run 120A continuously if he wants. (I doubt heās usually flying around that fast, though)
are too high. Drop them back to 10 and see if you still have the same issue. Autotune can make these a little high sometimes. This is one of the things I want to fix.
If you have set these parameters manually:
ATC_ACCEL_P_MAX,
ATC_ACCEL_R_MAX,
then they may be too high. You could try dropping them back down to 110000 and see how you go there.
Yeh, I normally only see 120A as I punch out from a stationary start or in a turn. Most of the flight I am around the 60 to 80 amps. If I push really hard I can flatten the battery in under 2 minutes. Obviously hover is much lower.
Lets keep on going up until you clearly see oscillation on each step then back off until it goes away. And could you send me the log of your test so I can see how the aircraft performed.
