I look at the results of Autotune. I have not been able to get a rate noise measure into the logging yet.
You can also do a full rate logging flight and then look at the FFT results in mission planner.
Hi Leonard,
Can one set the buzzer to disabled in the code or not to beep on mode change?
Henry
Ok, I must admit that I am not sure it is the vibrations. I just can’t find the discussion(s) about it. I first realized it was related to the buzzer was when I had a battery failsafe and looked at the mag data. But due to the IMU mismatch the devs involved in the discussion pointed to vibrations. As soon as I switched to an older firmware (with no buzzer tones when switching flight modes) or when moving the buzzer away from the damped platform where the autopilot was mounted on, all was ok. So all tests point to the buzzer. But not necessarily vibrations.
I have not tested it but Complete Parameter List — Copter documentation should do it. You should be able to test it on the desk. If I remember correctly this does not disable the startup sounds - but the flight mode switching sounds.
Do you see it from the final PIDs or the autotune data logged? If it is the autotune data it would be awesome if you could post two screenshots - one with noise and one without - for comparison.
Here is a picture of the buzzers I removed from my Pixfalcon controllers:
The one on the left caused the interference when switching to Alt Hold and the one on the right seemed fine.
I replaced them both with the buzzers I cannibalized from this board and mounted them far from the FC
Hope this helps someone.
Thanks Thorsten, I will investigate.
Here it the link to a discussion on drones-discuss about interference of the buzzer:
https://groups.google.com/forum/#!msg/drones-discuss/1xgJUpENNO4/X5L0aktgVqoJ
Randy mentions that “This is definitely vibration.” But some of my tests (see last message) indicate it could also be something else.
Thanks Thorsten,
That works as you explained.
Also found this comment under the video in Youtube:
“Cédric DELAIN11 months ago
I’ve solved the “rocket jump” when I switch to Altold or Loiter mode by disabling the internal buzzer of the Pixfalcon. I have a deep look inside my logs and I discovered that accZ was affected at the moment I select one of these mods. I’m currently flying with 3.4 RC2 and I don"t know if this parameter exists in the previous version (cf arducopter wiki). Hope this help.”
I did some flights and I am happy with the performance. A lot more stable in the wind.
Thanks for all your help Leonard I really appreciate it.
Henry
Hi Leonard,
Sorry to bug you, but can you please suggest the settings for a Flamewheel F450 Quad and for a F550 Hexa of the following parameters:
INS_GYRO_FILTER -?
INS_ACCEL_FILTER -?
MOT_THST_EXPO -?
and the limit for these parameters
ATC_ANG_PIT_P -?
ATC_ANG_RLL_P -?
Is 15 to high?
Henry
Thanks all for the buzzer issue. The first time we saw this it was on a iris where the buzzer caused both IMU’s to go bad. Here we are obviously getting just one because that one is in just the right spot on the board.
Great info, thank you!!!
Hi Henwilsch,
I would go with:
NS_GYRO_FILTER -40
INS_ACCEL_FILTER -40
MOT_THST_EXPO -0.65
ATC_ANG_PIT_P -10
ATC_ANG_RLL_P -10
As safe parameters. I would consider dropping the filter frequencies to 20 and 10 on the D filters if you find you have excessive noise issues.
Sorry for the slow reply I have had a crazy few months.
Hi Leonard,
I would suggest to move core recommendations from this thread straight into the wiki for arducopter into a separate section on how to setup pids for a small racer pixhawk based model.
i went into almost week long ordeal fighting same exact issue and found this thread just thx to pure luck.
https://discuss.ardupilot.org/t/need-help-severe-shaking-on-roll-axis/29823/9
Your recommendations were the key - on filtering and startup pids. as i only dealt with large and medium models before i could not figure out at all what was the issue with oscillations and jigsaw output on RCOU.
Thanks again for your help and support!
The key was lowering P gain, But and a big but, the mission planer extended tuning does not allow it to be lowered any lower than 0.080, and it needs to be around 0.050.
Go in to full parameter list and tune these:
ATC_ART_PIT_P 0.05
ATC_RAT_RLL_P 0.05
INS_ACCEL_FILTER 30
INS_GYRO_FILTER 60
I could tell but the fast oscillation it was too high P-gain. This is on a 4 year old 6G quad (thrust to weight ratio measured on filtered ACC Z axis in BF, hover to punch out), my normal quad is 9G and its considered a tanker, the new stuff is +13G. Can someone tell mission planner dev(s) to open up the tuning range, a low of 0.080 is probably fine for AP rigs, but nowhere close for the new mini quads requirements. I recommend 0.020 as a new low setting in “extended tuning” page.
it is correct. also, as i posted in rcgroups - the PSC_ACCZ_FILT parameter can also be causing ‘up and down’ jumping syndrome on small 6" and smaller models, and needs to be set to 40 or 80 Hz as well. as of to use 30, 40, 60, 80 - it really depends upon level of vibrations and desired agility.
May I ask the meaning of increasing ATC_RAT_PIT_FILT from 20(default) to 40? I did not fully understand the description in doc about ATC_RAT_PIT_FILT.
And why increase INS_GYRO_FILTER from 20(default) to 40. but decrease INS_ACCEL_FILTER from 20(default) to 10? the doc states “This can be set to a lower value to try to cope with very high vibration levels in aircraft.” I think small quad has higher vibration than big quad?
Thank you very much
I have a discussion here that would be a good place to make recomendations for parameter limit changes and defaults feedback.
I organised the new wiki tuning page to try to cover most of the introductory tuning questions.
hi @Leonardthall thank you very much. Your tuning instruction guide really saves my life (and many other people, I am sure)
Would you mind further explain the reason of increasing INS_GYRO_FILTER? Look into the source code, I think it is the cutoff frequency of low-pass filter for gyro. But I do not understand why increase it for small quad. I think increase it will let more noise enter EKF? And small quad usually has more vibration.
I do not understand what ATC_RAT_RLL_FILT do, too. I still not get it after dig into the source code. Would you mind giving me a little hint?
Thank you very much
The filters reduce noise but increase latency. The smaller and faster the aircraft the more important it is to minimise the latency. So this means we must increase the filter cut off frequency. To help with this these small aircraft have noise that is also a much higher frequency than larger aircraft.
The other thing to mention is the INS_GYRO_FILTER does not have any impact on the EKF.
ATC_RAT_RLL_FILT is the D term filter. If you look at some PID loop videos you will see that the D term needs to be filtered because it tends to increase gain at higher frequencies.
