It’s all your effort and @dkemxr@amilcarlucas@Clogz@Axel1 thank you so much for all the inputs shareed by you guys . This was not possible without your help
So we did the showcase today and observed some oscillation.
Did 2 missions at different altitude and payload of 9 kgs which was dropped 3 kg at a time (3times)
We observed the oscillation when the drone was reaching waypoint
In the second flight(log 30m altitude) when we observed oscillation we took over in loiter mode
In the first flight (log 50m altitude) when the oscillation was observed we let it reduce by itself and there after took over loiter mode to go over drop Lovation
I noticed Des roll and att roll in the logs and can see some issue , can someone have a look and advise is it beucsse of bad pids in the roll axis ?
@sauravhobyy hey could you help me out!!, which pdb have you used for this and current sensor i have used several pdb and mauch sensors( current sensors) which has been fused.
also im using hobbywingX11 with 12s 22000mah *2, my drone bounces in loiter mode with empty weight and flies stably in stabablize mode.
