Hi all,
I have 2 questions but I figured I would knock them both out in one post:
Right now I am working on configuring my beagle bone blue to control a skid steer rover with 6 wheels using ardurover and mission planner.
Question 1: I want to test the servo outputs of my beagle bone to confirm that I have the board configured correctly before mounting it in my robot. I attached an oscilloscope to my PWM pin on the servo connection and noticed that the 7 and 8 pins on the board are always outputting 100% duty cycle signals, even when the board is disarmed. I decided to reflash my board to remove ArduRover incase something went wrong in my download. This caused for pin 7 to stop firing, but pin 8 continued. After putting ArduRover back onto the board, pin 7 was back to always outputting. My question is if this is expected with this board and ArduRover or if my hardware is at fault.
Question 2: I have not been able to find an explanation of which pins of the beagle bone correspond to the different servo settings on mission planner. As it stands right now, when I connect to my board using mission planner I am presented 16 servo outputs that I can configure. I thought that the BBB had the 8 servo pins and 4 built in motor drivers. Is it that the first 8 servos in the mission planner settings correspond to the 8 servo pin outputs and the later outputs correspond to the motor drivers?
I appreciate any guidance anyone may have! Thanks.
