1600mm diameter hexacopter assembly
Hello everyone, I am a beginner in drones. Currently, my mentor wants to build a hexacopter with a full load capacity of 30kg to 35kg, and the desired payload is 5kg; of course, the larger the payload, the better. The flight controller I have chosen is Pixhawk, and the frame has a wheelbase of 1600mm. I am unsure how to choose the flight control firmware, and for the motors, I am selecting them based on a thrust of 5kg per motor, then choosing the appropriate ESC. Although this may seem a bit silly, I really don’t know how to proceed and sincerely hope to receive advice from all of you.
Get a subscription to ecalc.ch and it will help you with some of your estimations and component selections. 30kg of thrust (5kg x 6) will not be enough to control a 30-35 kg drone.
Since you’re posting on the Ardupilot forum, the only answer to the firmware is Arducopter. :slight_smile:
Look up the Ardupilot Methodic Configurator. It will help you set up your drone once you have the parts. It might seem like a lot at first but it will save you a lot of time and stress in the end.
