Hi Guys,
Just checking to see if anyone knows of a 100v 300amp volt/ammeter that is compatible with the cube.
Thank you
Shaun
Hi Guys,
Thank you
Shaun
As far as compatibility goes both the voltage and current sense inputs are 3.3Vdc max. A voltage divider and a big ass shunt resistor or inductive sensor… I don’t know of a Power Module made that meets that. Mauch makes 14S 200A units.
Thank you for the reply.
