Yea I had a cracked tooth that i was able to talk the Dentist 3D cap it even know it was close to the root. I love the Ceric machines. Ok to bad about your vibration and sounds like your set on the soft mounting. wish you luck,. If you had Photoshop all you do is to lower the compression value to 4.
here is a old tip from the cube page from the designer of the Cube [Philip Rowse) “Hard mount your system on a rigid frame. if after doing this, your logs show that you are having vibration issues… then get assistance in designing a correct isolation mount. This will only be needed on the 1% of strange frames or petrol vehicles. always get high speed logging data before attempting to use additional isolation.”
