Another failed launch of the s800. I have absolutely no idea what went wrong with this. Be good if someone could take a look to try to understand what on earth is the problem!
You have AHRS_ORIENTATION set to 100. Is that correct ?
Didn’t check your previous log but worth a look if not set up by yourself. How do you calibrate ?
@kikislater
The board orientation (AHRS_ORIENTATION) seems to be OK, otherwise the artificial horizon in the video above would not match with the real horizon.
@craigy72
A closer look to the log file shows a few other details:
a hefty throw with a lot of twist until the plane came inverted (ATT.Roll close to -180 degrees)
huge amount of vibrations when the throttle is applied. The vibrations are big enough to create clipping on the sensors. It also correlates to the typical sound of a unbalanced prop in the video.
