Hi!
Myself and a group of people are working on a project involving the 2450GPS, and we’d like to get it into station mode.
We’ve experienced the same issues some other people on here have reported, where the WIFI.txt doesn’t seem to work. After updating the firmware (to the most recent Dec 2017 version) I can replicate the issue where having a WIFI.txt on the card means it no longer creates its own access point (i.e. it seems to be attempting to connect to our network) but I can’t see any activity from anything else on the network using Wireshark.
I’ve hardcoded the SSID and key into the Sonix firmware as suggested, but this doesn’t seem to have helped at all. I’ve also used the dev console to run the wifistation command separately, with the same results (reboots and doesn’t host but doesn’t seem to connect too)
For reference the network we’re currently attempting to connect to is simply a virtual WLAN running on a Win7 laptop (as here) which I think may be an issue. We will have access to a router very soon but haven’t been able to test it. Do you think this is likely to be the problem, or are there any other things I could attempt in the meantime?
Thanks.
