I had this cube running great with the 3.7 DEV firmware. When I installed the latest stable (3.6.10) firmware, I get “Initializing APM” popping up over and over again in the message window and “NO GPS” in the flight deck display. It also won’t calibrate accels nor compass. I’ve tried a few things already:
Fresh MP download
Reset the board using EEPROM
Switched firmware back to 3.7 DEV then to 3.6.10 again
Multiple boards
I’ve had this exact problem with all 4 of the yellow cubes I have.
If you have any feedback/ideas for anything else to try I’d appreciate your input.
G’day Ben,
I’ve moved this to the Cube support area for you. Cube Yellow is still a new board, hopefully @proficnc or someone from his team can help you out.
