Im running the latest version of arducoptor v3.1.5 when i command the quad to turn yaw right it turns fast and when i turn yaw left at full left stick quad barly turns if i hold the quad down motors 3 and 4 spin fast aplying yaw and 1 and 2 spin slower iv manualy programed my esc,s and did them through apm no change and i put 2 new motors on 1 and 2 im at a loss i cant figure it out if anyone has had a problem like mine i would be greatful for some help thanks
@Mikerc3d
How about providing tlogs and/or data flash logs to help troubleshoot your issue.
Regards,
TCIII GM
This is usually a sign that the motors/props are not lined straight up and slightly tilted. Use a bubble level to check each motor hub and adjust. We’ve had this happened awhile ago and took 2 days to figure it out.
The logs would show the CCW motors working harder than the CW ones. A clear giveaway.
Ill take alook but you can hear the rpm diffrence between the 2 motors for left ya and the diffrence for the right yaw when applyied
