I’ve managed to get Yaapu telemetry working with a few different RX and flight controllers but the above combination has me beat. There’s a post here with the exact same hardware that says to connect from the Sport on the X8R to TX1 on the H743 and then set serial 2 on the H743 to protocol 10 and Options 7. Well, no go for me. I’ve tried using the TX pin and the RX pin on the Matek and a lot of other options but again, no luck.
Does anyone have the same setup working that they could share the configuration?
Turns out I was defining the wrong serial port. I have the telemetry from the receiver connected to pin Tx8 on the Matek and was configuring serial port 8 in ArduPilot. But pin Tx8 maps to serial port 5. Once I fixed that it worked great!
