Hello!
So far I have used the Jumper T18 with the FrSky R9 Slim + (Accst, Flex, Fport) receiver with Yaapu telemetry. Everything worked fine except for the small telemetry range of about 100-200m.
I decided to buy a new FrSky R9 Slim + OTA (Accst, Flex, Fport) receiver, I have a problem with receiving Yaapu telemetry, it does not work. I think there is a problem with the telemetry cable not compatible with this receiver.
Do you know what to do to make it work?
Thanks!
use it with qx7. everything work fine. R9 Slim+OTA. Latest ACCST FW in R9 TX and Slim RX.
@Alexey_Degterev is your telemetry responsive? I have similar set-up but the refresh rate is pretty bad, several seconds lag on F405 Wing
i don’t see this problem.
