Y 6 copter build
Hello everyone.
I wan to convert this Hobbyking h600 to a y6 and need some advice on FC placement.
The distance from the middle of the front motor to the middle of the rear motor 72 cm. Am I assuming correctly that halfway 36cm, would be the center of thrust and that this is where the FC need to be placed, or do i need to place the FC as close to the CoG as possible?
Hi, it doesnt need to be right on the CoG. If you are a long way off you can specify with parameters how far its away but generally for a frame that size its not needed.
Regards,
Chris
Thank You Chris.
I also got the following advice. Measure equal distance from each arm in and mount in the middle of that.
