The code is being developed and built using QT Creator. You can using the Qt qmake create a xcodeproj directory, but it will not be included in the repository. I’m not sure the Qt4.8 opensource version as the most up to date convertor. It maybe only when we move to Qt5.x we get support for Xcode 4 and 5
May I ask what is the configuration of Qt and Qt Creator you are using?
I have this problem of the breakpoints always being ignored in Qt Creator the 2nd time I run debug.
