Thank you for your development and activity on forums. It helps a lot of people. I admire Ardupilot autopilot system.
This is not related to Ardupilot, but it can help many beginners in Ardupilot development.
The problem with WSL2 was like a sore tooth. The guide was insufficient, and changing the SITL aircraft’s voltage led to unexpected crashes. I think there should be a more detailed guide, and that is why I am posting this question here for others’s information. I’m imagining that I edit ardupilot wiki if I reach certain level of programming.
Changing the address to “0.0.0.0” didn’t work. I changed the address to the vEthernet’s IP address, and it worked.
After that, another problem occurred. Actually, this is why I ran SITL in WSL1 for a very long time, instead of using WSL2. This time, I decided to move to WSL2 to perfect my system without any flaws
and I was able to run Rover and Plane instance by adding “–count=2” option but it is not perfect solution. I still found no perfect solution for running Rover and Plane Instance in WSL2.
