As you’ll see in the video, the motors barely responded to stick input. This is using dshot150 in the video, but the same results in using the motor sliders in the blheli32 configurator
Is “Low RPM Power Protect” enabled on the ESC’s? That has cause many people with low kV motors to scratch their heads.
That ended up being the issue!
Cool, easy fix! Drove me crazy the 1st time too.
