I lost two quads in separate accidents when there was loss of one motor. In the first case, a bullet connector separated between the ESC and motor, and in the other accident a propeller blade separated from the aircraft. These crashes has made me wonder how hard would it be to make Arducopter more robust and compensate for the loss of a motor
You just need to use 6 or more motors and it will keep flying.
Gee thanks, Captain Obvious! I was hoping for a solution for quads…
Physics is a b*ch, a quad with three motors is not flyable. The best that can be done is a high-speed continuous yaw, with some leveling and a quick descent (based on the original weight/thrust ratio). However, if I recall correctly, the algorithm for it is patented.
Damned Physical laws! A continuous yaw/quick descent might minimize the damage… When I complete my build, I will endeavor to do a thorough physical inspection prior to each flight…
You never said anything about quads…
Both of your lost are caused by mechanical quality issues.
I can’t say what the rason was in your special case but
in general most of such issues can be solved by preflight checks and maybe not allways using the cheapest solutions.
One was lost due to a bullet connector coming apart in flight. Perhaps a thorough visual preflight inspection would have caught it. At any rate, I use heat shrink to insure those connections don’t come apart. The other crash was due to a propeller blade separating from the hub - again, perhaps a close visual inspection beforehand woluld have caught that. I will endeavor to conduct thorough visual preflight inspections before each flight.
A common enough occurrence with anything other than a soldered connection.
