I’m trying to follow Ardupilot Tyro129 guide. It says there that target should be Matekf405.
However, I’ve tried all Matek f405 versions and I always get one of those errors BARO and INS initialization.
When I flash Betaflight MatekF405STD - works just fine. (I’m wondering what bf does different that same target works on it? )
Anyway I’ve run out of ideas and planning to dump those fc.
Anyone has any idea what is the problem?
Hi, I did my own research in the mean time. Yes the hardware has changed, that is the problem, original matekf405 is with mpu6000, and this one is using BMI270. Is there an easy way for me to get source code and recompile?
That’s not a MatekF405STD - it’s a clone. If they have replaced the IMU then you will have to do a new hwdef for the clone. Matek don’t make one with a BMI270 and the STD is EOL anyway, so the hwdef won’t get updated.
