Im hoping i can get some info here to help me over this problem i’m having. My quad seems to hover great in stabilize mode I have performed the auto trim and now im working on try the autotune. But when i put it into the loiter flight mode it it takes off forward and to the right. I’m guessing that i need to start adjusting the loiter PIDs.
Current setting are:
Loiter PID P1.000
Rate Loiter P:1.000 I:0.5000 D:0.0000 IMAX:4.0
I have also attached the lof file from the flight.
Log File C:/Program Files (x86)/Mission Planner/logs/2014-11-03 17-43-51.log
Size (kb) 579.38671875
No of lines 9804
Duration 0:06:13
Vehicletype ArduCopter
Firmware Version V3.1.5
Firmware Hash 3c57e771
Hardware Type APM 2
Free Mem 1186
Skipped Lines 0
Test: Autotune = GOOD - incomplete autotune attempt started @7121
Test: Balance/Twist = GOOD -
Test: Brownout = GOOD -
Test: Compass = GOOD - No MAG data, unable to test mag_field interference
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: GPS
Test: GPS = GOOD -
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = GOOD -
Thanks!!!
