I’m setting up a pixhawk to a long range system (i’m using ImmersionRC EzUHF 433MHZ). However, I can’t find a better tutorial on how to go about it. Is there anyone in this forum that can point me on where it’s hidden?
By the way I’m using Futaba radio T14SG model. Link my TX into trainer port.
This is how I attached my RX to my Pixhawk (pls. see attached).
I have the same Equipment and so far not solved the connection between Pixhawk and EzUHF RC. I have connect it the same way as your picture shows but my servos dont move.
Do i have to change some settings in Futaba T14SG?
Can you tell me some details how did you solved it?
Can you tell me some details how did you solved it?[/quote]
You need to set the reciever to output PPM first. Use the EZUHF USB upgrade tool.
Just spent days trying to figure this out myself. What I found in my plane installation is that I needed to send 5v to the servo output rail through via BEC.
