Wind correction
My plane is quite well tuned on a Pixhawk and flies well autonomously but isn’t quite there with wind stabilisation when flying on Auto mode.
There is a lot of wing movement up and down when it is just a bit gusty but I can’t work out if there’s not enough correction or too much and it is over compensating.
Which logs will can I check to see this and what do I look for?
Which of the PID values will I have to change?
a DF log is what is needed. Note that some planes will always be affected a lot by gusts. Tuning can help, but can’t eliminate it.
Here is the bin file for this flight. It was 5mph wind gusting to 11mph. The plane was rolling around quite a bit when a gust hit it.
http://www.medifarm.co.uk/16km_flight.BIN
